Hi Team,
Our customer needs to control the opening of an N - Channel MOSFET via the RESET pin and would like to understand whether this is possible by connecting the RESET pin to a voltage source via a pull-up resistor?
I have provided the datasheet for the device to serve as a guide but the customer would like to elaborate. In addition, can you also elaborate on the device works in latch mode, i.e. when it doesn't automatically reset the output of the reset pin even if the voltage drops below the threshold value?
Thank you for the help.
Marvin
