Part Number: LM74721-Q1
Is it possible to remove the ideal diode FET and connecting the anode and cathode together and only using the load disconnect as a load switch?
Cheers,
K
Cheers,
K
Hi Keshav,
Yes, LM7472x-Q1 can be used in Load switch only configuration as shown below. Short A and C together to the power path and leave the GATE pin floating.
May we know why you are considering using LM74721-Q1 to drive load switch FET while we have other controllers like Hotswaps which can do this job ? Is it because of the low Iq offered by the LM7472x-Q1 ?
