Other Parts Discussed in Thread: OPA365, INA126, TPS65133, LM27761, LP5910, TPS7A13
I would like to discuss the posssibility of using one LM27762 to supply positive and negative 2.5 V to power up around 10 OPA365 and an instrumentation amplifier such as INA126.
This opamp model was selected for its low distortion and zero crossover. They will operate mostly as amplifiers / buffers and active filters, in the range of tenths of kHz.
What are the key specifications I have to keep in mind in order to select the correct values for the capacitors and resistors to place around LM27762?
Thank you.
