TPS2513A: Replacement for GL889-20
Part Number: TPS2513A
Hello there,
We currently have a project with GL889-20-FJY part and we want to use TPS2513A as an drop in replacement ? Is this possible without any design changes?GL889-20 EDM.pdf
Best Regards
    Functionality wise yes you can replace GL889-20-FJY with TPS2513A. Although both GL889-20-FJY and TPS2513A are available in 6-pin SOT32 package, I cannot find the pinout for GL889-20-FJY from your attachment. You might need to modify your design based on the difference between the two chips.
