Dear Sir,
Can you use the tpsm63606 to generate the -15V/2A,using the input 12V?
Chai
Dear Sir,
Chai
Hi Chai,
Yes the TPSM63606 can be used to convert from buck to inverting buck for a 12Vin|-15Vout|2A application.
For more detail and guidance on this conversion, please refer to the app note (https://www.ti.com/lit/an/snva856a/snva856a.pdf).
Jimmy
Correct, this module can be configured as a buck or inverting buck-boost (IBB). See the IBB application example in the datasheet:
