Other Parts Discussed in Thread: TPS65262-2,
Hi Experts,
Our customer is using TPS65262-2 on their board but due to the stock issues, they will be using TPS65262-1 for replacement on a design they already fabricated.
The customer would like to know since the board they are using (designed for TPS65262-2RHBT) has all 3 enable (EN1,EN2,EN3) signals floating and they will like to mount TPS65262-1RHBT in same place of TPS65262-2RHBT will this be a problem for TPS65262-1RHBT which supports power sequencing? In addition, the Mode pin by default are pulled high.
Kindly let me know your feedback on using TPS65262-1RHBT instead of TPS65262-2RHBT in the same PCB.
I could provide the schematic if needed.
Marvin
