TPS62262-Q1: spec check
Part Number: TPS62262-Q1
Hi expert,
My customer is working on the worst case analysis for TPS62262TDRVRQ1 and need some data, could you please help to share? Thanks.
  • Minimum leakage current on EN pin
  • Minimum and maximum of quiescent current at IN pin.
Arie
  • Hi Arie,
    Min / Max spec of device is not characterized outside datasheet specification. I would suggest for worse case analysis, take max leakage spec on EN pin as suggested in datasheet and typical value for Iq.
    Please take look on new device  like TPS62850x-Q1 that shares advance feature in similar package area for new projects.
    Tanvee
