Other Parts Discussed in Thread: TPS92515
Due thte unavailabily of the TPS92151 we are trying to cope this situation installing a 5 turn trimmer in parallel to the sensing resistor in order to pick up a portion of voltage and send it (via trimmer brush) to the CS pin. In this way we are trying to adjust case by case the LED current. We experimented many damages to the chip, even without any activity on the trimmer.
Where is the problem? PCB layout was not so compact and the trac between trimmer and CS pin is going around some component in a way I do not like...
Is somebody able to give us some suggestion?
Roberto
