Other Parts Discussed in Thread: PMP
Hi Team,
What exactly is the purpose of the SYNC pin on the LM5118 ? I have 2 ideas in mind, I am waiting for your support on this issue
1- getting different outputs from 2 different LM5118s using an external signal ?
2- By connecting the LM5118s in parallel, the output voltages are the same and the output current is increased , For example, is it possible to set the outputs of 2 LM5118s as 24V/5A and connect them to each other with SYNC pins and make a common output 24V /10A?
Thanks in advance.
