Hi Expert,
Our customer use LM61460-Q1 to power off board load. So there might be "vout short to 14V " risk. what will happen to LM61460-Q1 if Vout is short to 14V ? Will it be broken? Thanks.
BR,
Elec Cheng
Hi Expert,
BR,
Elec Cheng
Hi Elec,
What is the input voltage in this application? If the input voltage is lower than the output voltage during the 14V short, then there may be some reverse current that will backflow through the SW node and damage the internal circuitry.
I would suggest reading this app note on reverse current causes and solutions: https://www.ti.com/lit/an/slua962/slua962.pdf
Jimmy
Hi Jimmy,
The input voltage is battery. Actually the case is that Vout is short to battery also. Under this condition, will it be reverse current? Thanks.
BR,
Elec Cheng
Hi Elec,
The part has been tested for VIN short to battery application, and it does survive.
Please see validation results below. There is negative current into the device, but after short release, the part recovers and regulates back to expected VOUT.
