BQ76952: Is there a risk of damaging the MOS by using a charge pump to drive the high-side MOS?
Part Number: BQ76952
Hi Team,
Could you pls help analyze the following questions?
Is there a risk of damaging the MOS by using a charge pump with a weak driving capability to drive the high-side MOS?
As mentioned in some external application reports, when the charge pump drives the MOS, the drive signal may be lost due to insufficient driving capability, or the MOS will remain on when there is a OCD or SCD, resulting in damage to the MOS. My customer asked if this could be the cause of the issue described in another e2e thread, " (+) BQ76952: DFET damage during short-term high-current discharge - Power management forum - Power management - TI E2E support forums"?  How to verify it?
Many thanks.
Hailiang
