Other Parts Discussed in Thread: TPS61165
Dear TI Team,
TPS61165 is used as the backlight power supply of LCD screen. At present, 1/5 of the prototypes's LCD displayed abnormal After investigation, it is found that the output of SW pin of TPS61165 is abnormal, and the impedance of SW pin to GND becomes lower. After replacing the new device, the LCD function can return to normal. Attached is our schematic, please help to check, thank you!
