Hi team,
My customer has some question on the usage of BQ25616, please see the questions below.
1. What is the relation between these two parameters?
Customer concerns that if we have K value as 715 (Axohm), Does the fast charge current regulation accuracy change due to K value close to Max or min value? Because this might affect the max charging current setting.
2. From datasheet page 19, how to set it as "Set by ILim pin" for all time. how to connect D+/D- to achieve this?
3. From datasheet mentioned VBUS rising without battery, my customer concerns that what if VBAT(4V) connected, when will charger start charging? It looks like charger is acting as a boost.
