TPS659037: Need to write TPS6590378ZWS to OTP
Part Number: TPS659037
Other Parts Discussed in Thread: AM5718,
We are planning to use AM5718 as shown in Fig.1, but we think that all sequences can be specified by the pin settings of BOOT0 and 1 at the initial startup.
Is it okay to recognize that there is no additional work to write to OTP?
TPS659037 User's Guide to Power AM574x, AM572x, and AM571x - Figure 1. Processor Connection With TPS6590378ZWSR
https://www.ti.com/lit/ug/sliu011f/sliu011f.pdf
Astro
  • HI Astro,
    The TPS659037 family of devices is not user programmable so the devices are programmed from the factory and will not require that you configure the OTP. You will need to decide if your system will required BOOT=0 or BOOT=1. The differences in these settings can be found in Table 5 of the user guide you linked to above.
    Layne J
