You can do that design with a bridge rectifier and a flyback converter.
The following link will bring you with bring you to an 85V to 265V AC to 5 V/1A reference design using the UCC28711. This design uses a bridge rectifier and a flyback step down converter.
https://www.ti.com/lit/ug/sluua12/sluua12.pdf
The following link will bring you to an 85V to 265V AC to 5V/2A reference design using the UCC28704.
https://www.ti.com/lit/pdf/sluubf1
The following link will bring you to the TI reference design library. Just enter in your design requirements and the tool will search the reference design library. Chances are there is already a reference design that will meet your specific needs.
https://www.ti.com/reference-designs/index.html
You can.
These reference designs are actually evaluation modules and you can order them to evaluate. It may be worth while for you to order one of these EVMs to evaluate on a 400 Hz 115V AC line. It will work fine.
