Other Parts Discussed in Thread: LMG1020
I am trying to use the UCC27611 GaN driver to drive the Laser Components QuickSwitch pulsed laser diode (which consist of a high current switch, charge storage capacitor and pulse laser diode in one package). The Quickswitch application note suggests using the TI UCC27611 but recommends the +Vdrv be 5.4 volts.
Can an external LDO or other source be used to create a slightly higher and possibly faster drive voltage by connecting the output of a LDO regulator or other source to the VREF pin (through a zero ohm resistor)?
If so, is there a small LDO voltage regulator or other part that TI would recommend to accomplish this? Looking for the smallest footprint part to accomplish this.
