Other Parts Discussed in Thread: TPS7A02,
Hi, our customer had a question about the TPS7A02/3 accuracy, in terms of output drift over time. This is for a grid monitoring application, where they are using the LDO output as ADC voltage reference for some non-critical measurement functions.
The load and line regulation, as well as accuracy, are covered over temperature and well documented in the datasheet. Do we have any info we can share on LTD or stability? Requirements is for <3% following 75C/85%rh for 1000hr.
Tristan
