Hi Moheddin,
I'm updating about your request of previous my e2e thread.
Here is my thread : (+) TLV62084: TLV62084 Switching Frequency vs Load Current Characteristics - Power management forum - Power management - TI E2E support forums
Below is what you requested.
1. Vin measured at the IC pin
2. Inductor current waveform
3. switch node voltage including TON time.
4. PCB layout to check the VOS pin connection.
Here is our data.
Default(VIN-5V,VOUT-1.2V) waveform.zip
In addition, there is only VOUT=2.5V in the datasheet according to the current switching frequency chart, so a comparison test was conducted as follows.
Why is this difference happened?
The test condition is (VIN=5V, R1=180k,R2=39.2k)
As in the above, it also shows a difference from the chart values below. (approximately 0.6MHz)
Frequency(MHz) |
1.98 |
1.63 |
1.90 |
1.87 |
1.85 |
1.82 |
1.77 |
1.71 |
1.65 |
1.57 |
Current(A) |
0.2 |
0.4 |
0.6 |
0.8 |
1.0 |
1.2 |
1.4 |
1.6 |
1.8 |
2.0 |
Graph on the data sheet .
Further inquiries
- What is the changing current section between PWM and PFM?
Could you please send your feedback about my each questions?
Michael
