Other Parts Discussed in Thread: TPS7A20
Hello support team,
Customer ask if TLV707 has internal Reverse current protection between VIN and VOUT, because of abs max VOUT spec on datasheet. I assume that TLV707 has no reverse current protection, because internal block diagram shows internal parasitic diode. Is this TYPO?
TLV707
Customer point out that TLV707 should use description like TPS7A20 if TYPO. Or does TLV707 have any specific reason for the description?
TPS7A20
Koji Ikeda
