Hi team,
Could you advise the maximum tolerance of Isd over temperature at given input voltage?
The datasheet EE parameter specifies max tolerance at Tj=25c, so I would like to know this value over temp.
I found Isd vs temp in Figure2 in the datasheet but it seems this is typical value, correct?
I would like to know the max value over temp and process variation.
regards,
