Hi Team - customer question below:
If the ILIM pin is left open, the device will switch to it’s internal current limit. Previous analysis also stated that a fault indication on the SNS pin would be set in this scenario but I couldn’t find anything in the datasheet or pin FMA documents backing this up.
Can you please confirm this for us: If the ILIM pin is left open, does the SNS pin report a fault?
Thanks!
