Hi team,
Could you advise the maximum value of Isd over temperature (TJ=-40c to +150c)?
I would also want to know the max variations of Isd at VIN=16V.
regards,
Hi team,
regards,
Hi Gui-san,
Does it includes process tolerance(part to part variation)?
regards,
Hi Shinji
The data are acquired by testing large number of devices and get the normal distribution.
Thanks and best regards.
Hi Gui-san,
From the Figure 8-2, the maximum shutdown current seems 1.5uA maximum at 25c,
but the spec is 6uA maximum for TJ=25c. Max standby currrent is 3.6uA even for +150c from the Figure 8-2.
Does it mean there is a large amount of variation in test limit or test condition (TJ=25c)is typo?
regards,
Hi Shinji
The spec in EC table is the Isd under 25C and Vin=13.5V.
You can refer to the Fig 8-2 for the full temperature range and Vin range data.
Hope that helps. Thanks and Best regards.
Hi Gui-san,
Fig 8-2 data (max1.5uA) is much smaller than 25C data on EC table(6uA max).
Could you explain why 6uA max?
regards,
Hi Shinji
Fig 8-2 is plotted by typical value under different conditions.
