Other Parts Discussed in Thread: TPS62872
Hi team,
When we want to set the default output voltage to 0.85V whose load current is 10A, should we use TPS62872QWRXSRQ1? And should R_VSEL be 6.2kOhm?
When they don't use I2C, could you tell how to deal with the SDA & SCL pins? They just need only 0.85V.
Noriyuki Takahashi
