Hi team,
Could you advise if there is any power up/down timing sequence requirement between VCC and SENSE pin?
Could you also advise how long should I wait before sending SPI command after first power up the device?
regards,
Hi team,
regards,
Hi Tsuji-san,
Sorry for replying late.
Vcc should be the first. The others may not have any sequence. And the time SPI should wait after Vcc doesn't have a recommend value. I have seen 1ms in other cases.
BR, Gracie
