Hi team,
If we connect ILIM to GND and we met reverse battery issue, will there be any reverse current pass through ILIM pin? Thanks!
BR
Jiawei
Hi team,
BR
Jiawei
Jiawei,
There will not be an explicit path as there is a clamp on the pin, however the datasheet recommendation is to float the pin if you are not using the current limit (and are just using the internal current limit):
We explain the path more in detail in the following application note:
https://www.ti.com/lit/pdf/slvae55
