TPS929120-Q1: EEPM6 Value Bit7
Part Number: TPS929120-Q1
we want to use the AUTOSS feature.
How do we have to configure the EEPM6?
According to the linked question it sais, that this bit (also according to the datasheet) does not exist anymore:
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/914560/tps929120-q1-eepm6-datasheet-issue
If I read back the EEP Register with the Demoboard GUI (with my board connected to RX/TX) I read Bit7 as 1 when I had the Auto SS aktivated in the EEPROM programming section in the GUI.
If we want to use it, should we not set Bit7 in the EEPM0 but with the µC after every startup in the CONF_MISC0, or how to activate this feature?
What do we have to consider for the CRC in EEPM15? Will it be correct?
Thank you
