Can the LLC topology be used if you need two power supply rails?
I need 12V @ 5A and 52V @ 2A. I would like to generate these off the same (single) transformer.
Is the LLC topology suitable for this?
All the app notes and LLC articles I have read only have a single output voltage.
I plan to use diodes for the 52V supply, perhaps in a bridge configuration, so only a single winding (not center tapped) is needed.
The 12V supply will be center-tapped and use SR's.
Any recommendations on how to do the feedback loop?
