Other Parts Discussed in Thread: LM5022
HI team,
to modulate the modulator in the LM5022-Q1 that generate the PWM signal. i need to his function transfer but i didn't find it. if possible, to recommend a document or application note.
Thank you,
Hi Abdelrhaffar,
Thanks for using the e2e forum.
We have several resources available for LM5022 design.
All relevant equations should be within the LM5022 datasheet in the Application and Implementation chapter.
Which topology does this design use?
For general calculations, I highly recommend the power stage designer tool:
https://www.ti.com/tool/POWERSTAGE-DESIGNER
For Flyback application, we have an additional calculator excel sheet:
https://www.ti.com/tool/FLYBUCK-FLYBACK-DESIGN-CALC
Please let me know if you need additional resources.
Niklas
