I have an LM6201 part with 4B A marking instead od A 4B as specified in the datasheet. Is this OK? Should the datasheet be modified?
I will check it with team, and give you feedback later. Thanks.
Aurora
Hi Ireen,
It looks like you posted two identical threads. I confirmed with the team and Shahram in charge will follow up on the previous thread. You can see his latest reply at the link below. I will close this thread. Hope this can help you. Thanks.
Aurora
