Other Parts Discussed in Thread: TPS92200, TPS54200,
I used this a example https://www.ti.com/lit/an/slua979a/slua979a.pdf to control a TEC module. Please note that I took the wrong value for Rsens and later changed this to 0.250R(measured). I don't have the TEC module connected yet, so only probing the output
Should I keep lowering the Rsens, it is already making a buzzing sound with the value. Or is there something else going on?
I connected the PWM pin to both 3V3 continuous and a PWM 50kHz, 50% (2V22)
125R Rsens
Rsens change to 0.250R
