Other Parts Discussed in Thread: BQSTUDIO, EV2400
I'm having an issue with the BQ27520-G4 that is on my board (custom design). The case I can reproduce is reading the device firmware ID will alternately succeed and fail with a NAK. I am waiting about 30 seconds between the two calls.
The success is here:
The failure is here:
As you can see, it appears that the BQ27520 is NAK-ing the command (CONTROL: 0x00), so we never get to the subcommand, nevermind the read. Is this normal behavior?
An interesting note is that if I try to read the battery internal temperature (for instance), the sequence works every time.
Thank you,
Jonathan
