Other Parts Discussed in Thread: BQ24075, BQ25895, BQ24295, BQ25616
When comparing different chips, the BQ24296 is marked as I2C or stand alone function. I want to incorporate this as a stand alone device for battery charging in a power bank device. I had a few questions regarding this.
Should I leave the host pins such as SDA, SCL, and INT floating?
I don't intend to use the thermal battery monitoring, what do I do with the TS pin? Connect the pin to a voltage divider as per the datasheet but use a 10k resistor instead of the thermistor?
