TPS6521815: EEPROM program
Part Number: TPS6521815
I have a question about "Note" in datasheet P45, 8.5.1 Programming Power-Up Default Values.
<Note>Only bits marked with (E2) in the register map have EEPROM programmable power-up default settings. All other bits keep the factory settings listed in the register map. Changing the power-up default values is not recommended in production but for prototyping only.
Regarding "Changing the power-up default values is not recommended in production," could you tell me the specific reason why it is not recommended?
Nishie
