Hi Team,
Could you please kindly help to check if TPS61240IDRVQ1 could work with operation TJ=127.8℃, from datasheet, it shows maximum value for operation Tj=125℃. If it is not suitable to use with Tj above 125℃, then do we have some other P2P device with Tj=150℃ which could recommend for customer, thanks a lot for your support to confirm.
Best regards
Jie
