Other Parts Discussed in Thread: TPS51487XA
Hi Expert,
My customer wonder if we have automotive Q1 grade PMIC to power LPDDR4 and LPDDR4X like TPS65296, can you please help recommend?
Thanks a lot!
Daoyan
Hi Expert,
Thanks a lot!
Daoyan
Hi Zhao
Could you provide the spec for customer application? VIN/Vout/Iout=?
Hi Xueliang,
It's for powering standard LPDDR4 and LPDDR4X, I though we had standard devices for powering it, do you possibly know it?
Thanks!
Hi Xueliang,
I got some information from customer, generally defaut input voltage is 5V output voltage is 1.8V and 1.1V and a reserved 0.6V, thanks!
Hi Daoyan
Sure, TPS51487XA and TPS65296 can support LPDDR4/4X and meet the JEDEC standard. the only difference is the max VIN for the two parts.
Hi Xueliang,
can you share TPS51487XA datasheet with me? Is it a Automotive Q1 grade? Customer don't need Non Q1 version, thanks!
Hi Daoyan
DS is attached, about your questions, I need to double check with related colleague and give your feedback tomorrow. thanks!TPS51487XA.pdf
Hi Daoyan
The TPS51487XA and TPS65296 can't support automotive Q1, sorry, we don't have parts that can support automotive Q1.
