TPS7A4101: TPS7A4101
Part Number: TPS7A4101
Other Parts Discussed in Thread: TINA-TI
Hi Team,
In my V-I circuit design based on amplifier, i need convert the 24V power to 3.3V and run the simulation in TINA, but unfortunately i can't find the
TPS7A4101 tina simulation model, could you please help check if we can run this LDO simulation as well in my TINA tool which is based on amplifier circuit. thanks.
regards,
Jack
  • Hi Jack,
    Please follow these steps to create a .TSM file for the TPS7A4101:
    1.) Download the unencrypted PSpice model (provided in the link within your E2E post)
    2.) Use the New Macro Wizard to import the PSpice model into TINA-TI (Tools-->New Macro Wizard). Give the .TSM file a name, navigate to the .lib file where you have saved it on your computer and select the TPS7A4101 model and use the Auto generate shape option.
    3.) Save the .TSM file and insert it into your schematic
    Stephen
