Dear Ti team ,
Got other frequnce ( beside the 1Hz /H/L )at the STAT pin when the BQ25616JEVM at the charger mode .
Dear Ti team ,
Hello Rence,
Thank you for reaching out via E2E. Do you have a battery or battery simulator connected at BAT pin during your test of the STAT signal behavior?
Garrett
Dear Garrett ,
-->battery simulator connected at BAT .
Good day
Hi Rence,
Can you please provide a waveform showing voltage at VBUS test point, voltage at BAT test point, and STAT?
Garrett
Hi Rence,
What you are observing is different than the STAT pin blinking at 1hz to indicate a fault condition.
For the without battery case the STAT pin is behaving as expected. It is repeatedly transitioning between indicating charge in progress and charge complete. This is occurring in a short amount of time because there is no battery connected, but the BQ25616J still charges the BAT pin output capacitor as if it is a really small battery.
Please let me know if you have any further questions.
Garrett
Dear Garrett ,
We can find out this behavior from spec where?(https://www.ti.com/lit/ds/symlink/bq25616.pdf?ts=1695802328540&ref_url=https%253A%252F%252Fwww.google.com%252F)
Thank
Hi Rence,
The behavior is not described in detail the datasheet because having charge enabled with no battery attached is not a recommended use case. The STAT signal is switching between its 2 standard states 'charge in progress' and 'charge complete' mentioned in the pin functions description.
The FAQ linked below describes the behavior in more detail. BQ25616J is not mentioned, but the STAT pin architecture is the same.
Garrett
