Part Number: TPS2660
From the datasheet for the TPS2660x, I see that there is there is pin (dVdt) that can be used to set the output voltage slew rate for in-rush current control.
Does this essentially fulfill the role of a load switch? If not, would there be any disadvantages to adding a load switch (such as TPS1H200A) to the output of the eFuse?
Thank you,
Michael
