Part Number: TPS610333
Other Parts Discussed in Thread: TPS63070, TPS61030, TPS61033, TPS61178
Hi team
I found TPS610333 show "Frequency synchronization" in the public page as below: but didn't find this function in datasheet, so whether TPS610333 has Frequency synchronization function?
And customer requirement as below :
Input voltage range :2.7~4.2V, output voltage 5V, output current 0.4A, Frequency synchronization function needed, internal switch or internal inductor both works. Current limit 2A~3A. small size
I didn't found a device that could meet the above requirement, so I proposal TPS63070,
May I ask do you have other better proposal for the above requirement?
Best regards
Irene qin
