Other Parts Discussed in Thread: GPCCHEM, BQ28Z610, BQSTUDIO
We're using the BQ27441DRZT-G1A fuel gauge in one of our products. We recently had to change our battery cell to a different manufacturer. I ran a relax, discharge, relax test and submitted the files to the GPCCHEM calculator to see if it will still work with our gauge. The report showed that the best CHEM_ID match for my battery is 2144, the BQ27441-G1A has a CHEM_ID of 0x0128. It also shows the following error for the 3 ROM based gauge families:
Warning: Generic ID Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recommended format, units and test schedule
I checked the format of my files and feel they adhere to the requirements called out in document SLVA725A.
I've attached my data files and the GPCCHEM report. Do you see anything wrong with the data files?
Rob
