KEEP UPDATING...
This thread provides a list of frequently asked questions for TPS922055 / TPS922054 / TPS922053 / TPS922052 LED driver. You can click on the below link to check the detailed answer for each question.
Design Tools
- [FAQ] Is there a calculation tool for TPS922055 / TPS922054 / TPS922053 / TPS922052?
- [FAQ] Is there a simulation model for TPS922055 / TPS922054 / TPS922053 / TPS922052?
CSP & CSN Pins
UVP Pin
TEMP Pin
COMP Pin
FAULT Pin
PCB Layout
Timing Sequence
- [FAQ] How to get a quick transition of TPS922055 / TPS922054 / TPS922053 / TPS922052 from shutdown into flexible dimming mode?
- [FAQ] How will TPS922055 / TPS922054 / TPS922053 / TPS922052 transform from shutdown into PWM dimming mode?
- [FAQ] How will TPS922055 / TPS922054 / TPS922053 / TPS922052 transform from shutdown into hybrid dimming mode?
Other Design Guidance
