Other Parts Discussed in Thread: UCC25800, UCC14140-Q1, UCC25800-Q1
The UCC14240-Q1 device uses a two switch "balancer-like" topology to regulate the COM-VEE voltage (Figure 7-2 in the UCC14240-Q1 datasheet).
Does TI have a device that has just this kind of regulator integrated to use as standalone voltage regulator for split-rail supply (higher power capability than UCC14240-Q1 output)?
A use case could be as a secondary side regulator for a bias-supply in conjunction with the UCC25800 (for higher power applications).
Patrick
