Hello team
could you please take a look on my customers question and comment on possibility combining the outputs
From what I understand they want to use the BUCK and the LDO for the same rail and basically turn off the BUCK if the system goes into sleep mode.
I could imagine they can or-ing the outputs together (diodes) but not short them straight forward
Customer:
I found this interesting PMIC (TPS65320D-Q1) on your website.
I have a couple of questions,
- Is it possible to short the outputs of the PMIC (Buck and LDO) together? so that when our system is in normal mode we will be using the Buck, while when we are in sleep mode we will be supplied by the LDO to improve the sleeping current.
Thanks!
Kind regards
Dierk Bronner | Senior FAE Automotive
