BQ51050B: Utility BMS
Part Number: BQ51050B
Hi team,
I use the BQ51050B to charge a 1300mAh 3.7V lipo battery in my circuit. The Lipo battery is equipped with a PCM.
To be on the safe side, I want to add a BMS but I don't know if the BQ51050B already has this function.
If it doesn't, should the BMS be added in parallel or directly at the output of the battery before the BQ51050B?
Best regards
