I plan to use TPS259620DDA in my design. The data sheet states that in order to select 5.7V overvoltage clamp I need to connect OVCSEL pin of the device to GND via 400K resistor. However, 400K is not a standard value. The standard value is 399K. How will using the standard resistor value affect the clamp voltage? Also, how will the resistor tolerance affect the clamp voltage?
Thank you,
Eric Bogomolny.
