Hi
I have a query about watchdog need your help.
From the register screen the DFW flag is setting. But the data memory PF status D did not enable the DFW.
Please refer to the attached screen.
Please help check it.
Star
Hi
Star
Hello Star,
This should be checked in Settings: Permanent Failure: Enabled PF D. This might be a private register.
Please share settings so I can provide the physical address the customer need to read from to confirm DFW is disabled.
Jose Couso
Hi Star,
I programmed the provided srec and it does not seem they have DFW enabled.
I also see that there's no PF enabled, can they just disable PF_EN in Settings: Manufacturing: Mfg Status init [PF_EN] ?
This should avoid this from happening.
Jose Couso
