Part Number: BQ27520-G4
In the document SLUA640 Host System Calibration Method there is a section Floating Point Conversion.
According to chapter 12 Floating Point Conversion there is a flow diagram that explain floating point conversion and there is a code example however there is an if statement is not correct:
} else if (tmpVal < = 1.0) {
while (tmpVal >= 1.0) {
tmpVal = tmpVal / 2;
exp++;
Please correct it, make sure flow diagram matches code example. unfortunately I trusted the code example to implement such conversion until I realized that if statement was not matching diagram flow. Therefore time lost.
The fix could save time for other users.
