Hello. According to section 10.2.1.2.3 of the TPS7H1111-SEP datasheet, the output voltage accuracy does not take into account lifetime drift. It is stated that "For this example, it is assumed the lifetime drift is minimal compared to the other sources of error and is therefore not added". To be as thorough as possible, I'd like to include a value for this in my accuracy calculation - could you give me a maximum value I could use for this? The datasheet mentions "Group C data" which may be used to aid this calculation. I'm not familiar with Group C data - is this something you can provide? If you could preferably instead give a simple indication of the maximum expected error for a given lifetime that would be much appreciated.
David
