Part Number: TPS62868
Other Parts Discussed in Thread: TPSM82864A, TPS62865
According to datasheet, output voltage can be selected between two output voltage registers by the VID pin.
For TPS628680ARQY, the VSET/VID pin is connected to external resistor to set start-up voltage.
Then after start-up period, Is output voltage set by Table 8-6?
How to set if I use same value after start-up, with start-up voltage?
