Please give me the PCN# & PCN letter for UCC2897APWR where the bonding wire was changed to CU wire.
I will close this thread a no response for a long time. You can re-open this thread if you have the answer to my question.
The wire information provided by TI in 2010 was Au wire.
However, it is now Cu wire material, and we are checking to see if there is a PCN for the material change.
How do you know the wire now is Cu while 2010 was Au? Can you provide any document to show?
2010 AU Wire information provided by TI.
Current Cu wires are information from the TI.com website (Material content search:www.ti.com/.../home).
Please provide the evidence of 2010 Au wire document to help to trace back and make inquiry.
I checked all changes since 2009 on UCC2897A and did not find a change record on the bond wire change so no associated PCN. If you can provide the evidence 2010 AU wire information, I can use that as a clue to try another time.
What is your concern on this Cu and Au difference in case no PCN can be found?
I checked with the source of the AU Wire information (TI Japan) to confirm the basis of the information.
However, they responded that the basis was unknown because the person in charge at that time was not available.
TI Japan has informed us that the 2010 Au wire information will be treated as a misstatement since there has been no change since 2009 based on E2E investigation.
As I mentioned, I checked the changes since 2009 and did not find such a change.
I do not know where to move on unless you can provide additional evidence such as some documentation or similar.
Again what would be the concerns at now that make you to look for the PCN.
TI Japan has instructed us to check PCNs through E2E, so we have asked them to do so.
Based on the results of E2E's confirmation, there were no changes or related PCNs.
TI Japan has confirmed that AuWire's information was incorrect.
Thank you for your support.
